G-SYNC 101: G-SYNC Ceiling vs. FPS Limit
How Low Should You Go?
Blur Busters was the world’s first site to test G-SYNC in Preview of NVIDIA G-SYNC, Part #1 (Fluidity) using an ASUS VG248QE pre-installed with a G-SYNC upgrade kit. At the time, the consensus was limiting the fps from 135 to 138 at 144Hz was enough to avoid V-SYNC-level input lag.
However, much has changed since the first G-SYNC upgrade kit was released; the Minimum Refresh Range wasn’t in place, the V-SYNC toggle had yet to be exposed, G-SYNC did not support borderless or windowed mode, and there was even a small performance penalty on the Kepler architecture at the time (Maxwell and later corrected this).
My own testing in my Blur Busters Forum thread found that just 2 FPS below the refresh rate was enough to avoid the G-SYNC ceiling. However, now armed with improved testing methods and equipment, is this still the case, and does the required FPS limit change depending on the refresh rate?
Blur Buster's G-SYNC 101: Input Latency & Optimal Settings
As the results show, just 2 FPS below the refresh rate is indeed still enough to avoid the G-SYNC ceiling and prevent V-SYNC-level input lag, and this number does not change, regardless of the maximum refresh rate in use.
To leave no stone unturned, an “at” FPS, -1 FPS, -2 FPS, and finally -10 FPS limit was tested to prove that even far below -2 FPS, no real improvements can be had. In fact, limiting the FPS lower than needed can actually slightly increase input lag, especially at lower refresh rates, since frametimes quickly become higher, and thus frame delivery becomes slower due to the decrease in sustained framerates.
As for the “perfect” number, going by the results, and taking into consideration variances in accuracy from FPS limiter to FPS limiter, along with differences in performance from system to system, a -3 FPS limit is the safest bet, and is my new recommendation. A lower FPS limit, at least for the purpose of avoiding the G-SYNC ceiling, will simply rob frames.
3898 Comments For “G-SYNC 101”
mahmcud
Member
mahmcud
Hey, I followed the settings in this guide (G-SYNC and NVIDIA V-Sync enabled, with the NVIDIA Max Frame Rate limit set to 3 FPS below my monitor’s refresh rate), but I’m having an issue: in some games, such as RDR2, GTA V, and AC Shadows, using NVIDIA Control Panel’s Max Frame Rate limiter doesn’t feel smooth while other limiters like rtss work normal. Is there any way to fix this?
Robi
Member
Robi
Hey Jorimt, i did some testing again and found that in Cyberpunk2077 Frame Gen increases your latency in less gpu demanding areas, what do you know about this?
Here is my testings:
Question: Does DLSS Frame Generation increase PC Latency when GPU utilization decreases? (Cyberpunk 2077)
My settings:
– DLSS Super Resolution: Quality Transformer Model 2
– DLSS Frame Generation: 2×
– FPS cap: 157 RTSS (Async)
– NVIDIA Reflex: enabled (By default when FG)
– G-SYNC and V-Sync (NCP) configured correctly
– All graphics max + Path Tracing
My observations:
– In demanding areas, NVIDIA overlay PC Latency is around 35 ms.
– In less demanding areas, PC Latency rises to around 55 ms, despite lower GPU utilization.
– With Frame Generation disabled, I get around 100 FPS and 26 ms average latency.
– Interestingly, switching to DLAA while keeping Frame Generation enabled increases GPU utilization and reduces latency again but only in the less gpu demanding area.
I’ve repeated these tests, and I can feel the difference in responsiveness, I play lots of FPS games and I can physically feel the difference between 35ms and 55ms this is not a margin of error from Nvidia Overlay LAT.
Has anyone observed Frame Generation causing higher latency at lower GPU utilization?
wbotter
Member
wbotter
Hey! Wondering if V-Sync is applicable to Gsync Pulsar monitors? I just got one, went from PG27AQDM to the XG27AQNGV after receiving not one but TWO defective PG27AQWP-W’s!!! After the second AQWP-W started intermittently dropping signal due to the UHBR-20 handshake failing, works flawlessly in UHBR-13.5 with DSC, but for a $1250 monitor, I’d expect it to work as intended. So, I ultimately gave up on the flagship and was just searching for 27″ or less 1440p monitors over the 240hz my AQDM was already giving me, and the Gsync pulsar caught my eye. I had a BenQ Zowie with DyAc+ a few years ago and loved it, so yeah the curiosity got me with this monitor. I currently have a 9800x3d, cl 28 32gb 6000mhz, and a 5070. (Yes, Ik my gpu is hardcore limiting my FPS). I play competitive games mostly, in “comp settings” (basically low everything), DLSS Quality or Balanced using Model K, and I’ll get 384fps peaks, 271 avg, 202 1% lows and an average PCL of 10. All captured using frameview in marvel rivals after many many many “change one setting,” *capture for 45min-1hr of gameplay,* did this increase or decrease performance? lol! (All without DLSS FG. I’m not opposed to DLSS FG 2x, but 3x and above my PCL climbs quite a bit.)
Anyways, got any advice to get the most out of the GSYNC Pulsar Monitors? Or same rules apply? Thanks!!
user2422
Member
user2422
In an earlier comment you mentioned that ULLM is somewhat inefficient compared to Reflex or a manual limit, if i were to use Gsync + Vsync + ULLM, would that starving of the max queued frames and the potential stutters that come with it even apply considering that ULLM is auto limiting the fps in this configuration? Like does it limit low enough to prevent this from even happening?
Also when using Gsync + Vsync and then only enabling ULLM via Inspector without setting max pre-rendered frames to 1 (which ULLM would’ve otherwise done if it was applied via NVCP or NVApp), would this then be just an auto limiter without the other effects of ULLM? I’ve tried this configuration in-game and the auto limit still applies but I’m unsure whether or not ULLM will have any other impact in this configuration.
eonjr
Member
eonjr
Hi, thank you for the guides! But I have something to ask. My laptop has a 300hz refresh rate that is also GSync compatible. I have it capped at 285 using a formula that I saw on a Reddit post a while ago (via NVIDIA APP > Max Frame Rate).
I unfortunately get this gray flickering during gaming but I can get used to it. However, what I cannot stand is, when I tried using editing software (like Adobe Premiere Pro), the flickering was also present despite me having turned off GSync specifically for that app (via NVIDIA App). Is there something I am doing wrong? What can be done to completely eliminate flickering for non-game apps?
wpDiscuz
