G-SYNC 101: Control Panel
G-SYNC Module
The G-SYNC module is a small chip that replaces the display’s standard internal scaler, and contains enough onboard memory to hold and process a single frame at a time.
The module exploits the vertical blanking interval (the span between the previous and next frame scan) to manipulate the display’s internal timings; performing G2G (gray to gray) overdrive calculations to prevent ghosting, and synchronizing the display’s refresh rate to the GPU’s render rate to eliminate tearing, along with the delayed frame delivery and adjoining stutter caused by traditional syncing methods.
G-SYNC Demo
The below Blur Busters Test UFO motion test pattern uses motion interpolation techniques to simulate the seamless framerate transitions G-SYNC provides within the refresh rate, when directly compared to standalone V-SYNC.
G-SYNC Activation
“Enable for full screen mode” (exclusive fullscreen functionality only) will automatically engage when a supported display is connected to the GPU. If G-SYNC behavior is suspect or non-functioning, untick the “Enable G-SYNC, G-SYNC Compatible” box, apply, re-tick, and apply.
Blur Buster's G-SYNC 101: Control Panel
G-SYNC Windowed Mode
“Enable for windowed and full screen mode” allows G-SYNC support for windowed and borderless windowed mode. This option was introduced in a 2015 driver update, and by manipulating the DWM (Desktop Windows Manager) framebuffer, enables G-SYNC’s VRR (variable refresh rate) to synchronize to the focused window’s render rate; unfocused windows remain at the desktop’s fixed refresh rate until focused on.
G-SYNC only functions on one window at a time, and thus any unfocused window that contains moving content will appear to stutter or slow down, a reason why a variety of non-gaming applications (popular web browsers among them) include predefined Nvidia profiles that disable G-SYNC support.
Note: this setting may require a game or system restart after application; the “G-SYNC Indicator” (Nvidia Control Panel > Display > G-SYNC Indicator) can be enabled to verify it is working as intended.
G-SYNC Preferred Refresh Rate
“Highest available” automatically engages when G-SYNC is enabled, and overrides the in-game refresh rate selector (if present), defaulting to the highest supported refresh rate of the display. This is useful for games that don’t include a selector, and ensures the display’s native refresh rate is utilized.
“Application-controlled” adheres to the desktop’s current refresh rate, or defers control to games that contain a refresh rate selector.
Note: this setting only applies to games being run in exclusive fullscreen mode. For games being run in borderless or windowed mode, the desktop dictates the refresh rate.
G-SYNC & V-SYNC
G-SYNC (GPU Synchronization) works on the same principle as double buffer V-SYNC; buffer A begins to render frame A, and upon completion, scans it to the display. Meanwhile, as buffer A finishes scanning its first frame, buffer B begins to render frame B, and upon completion, scans it to the display, repeat.
The primary difference between G-SYNC and V-SYNC is the method in which rendered frames are synchronized. With V-SYNC, the GPU’s render rate is synchronized to the fixed refresh rate of the display. With G-SYNC, the display’s VRR (variable refresh rate) is synchronized to the GPU’s render rate.
Upon its release, G-SYNC’s ability to fall back on fixed refresh rate V-SYNC behavior when exceeding the maximum refresh rate of the display was built-in and non-optional. A 2015 driver update later exposed the option.
This update led to recurring confusion, creating a misconception that G-SYNC and V-SYNC are entirely separate options. However, with G-SYNC enabled, the “Vertical sync” option in the control panel no longer acts as V-SYNC, and actually dictates whether, one, the G-SYNC module compensates for frametime variances output by the system (which prevents tearing at all times. G-SYNC + V-SYNC “Off” disables this behavior; see G-SYNC 101: Range), and two, whether G-SYNC falls back on fixed refresh rate V-SYNC behavior; if V-SYNC is “On,” G-SYNC will revert to V-SYNC behavior above its range, if V-SYNC is “Off,” G-SYNC will disable above its range, and tearing will begin display wide.
Within its range, G-SYNC is the only syncing method active, no matter the V-SYNC “On” or “Off” setting.
Currently, when G-SYNC is enabled, the control panel’s “Vertical sync” entry is automatically engaged to β€œUse the 3D application setting,” which defers V-SYNC fallback behavior and frametime compensation control to the in-game V-SYNC option. This can be manually overridden by changing the β€œVertical sync” entry in the control panel to β€œOff,” β€œOn,” or β€œFast.”
3709 Comments For “G-SYNC 101”
CodeDownfall
Member
CodeDownfall
Thanks for this guide, just a little confused. I mostly play Fortnite and have G-Sync ON and frames capped to 237 (240hz monitor) I have vsync OFF but after reading this I am confused. Should I have GSync and VSync on for my situation? Thanks!
ReflexArc
Member
ReflexArc
Thank you for the guide, jorimt. Another C9 owner here, blowing up your comments thread with questions. Forgive me if this has been asked, but I cannot get Gsync to engage at all when setting Vsync to “on” in the NVCP as recommended in that guide, as indicated by the Gsync On notification that I’ve got set to toggle.
Arguably, I am a Gsync n00b, so I may still be doing something wrong. I’m testing with Outer Worlds as it runs between 43 -70 fps on my 2080ti with maxed settings. If Vsync in on in NVCP (and off in the game), with frames limited to 57 in RTSS, I get no Gsync notification and clear stuttering and tearing within the 40-60fps range. If I switch Vsync off in NVCP, the notification pops, and the stuttering and tearing is eliminated. It’s weird. Not sure why it won’t work when following the guide. Any ideas?
22Green
Member
22Green
Guess my last post was little off topic and was deleted.
22Green
Member
22Green
Jorimt would you have any suggestions on this?
I just was gonna game (OLED C9 with RTX 2080Ti) and noticed 2560 x 1440 missing from NVIDIA control panel? It was listed with my old 1080 Ti 3 days ago, but the RTX 2080 Ti w/latest drivers just installed and G-SYNC enabled its missing. My HDMI cable is fine.
Theres 2 modes you can use for gaming. I wanted to game at 2560 x 1440 120Hz with G-SYNC instead of the demanding 4k x 2 k 3840 x 2160 60Hz
https://www.nvidia.com/en-us/geforce/news/g-sync-compatible-2019-lg-tv-available-now/
Select Display > Change resolution and apply one of these modes:
2560×1440 @ 120Hz for a 40-120Hz Variable Refresh Rate range
3840×2160 @ 60Hz for a 40-60Hz Variable Refresh Rate range
Little stumped on why that mode is not listed.
Thanks
nylander
Member
nylander
How much input delay does gsync add, if any at all? And I still don’t understand why vsync should be on with it.
wpDiscuz
