G-SYNC 101: G-SYNC Fullscreen vs. Borderless/Windowed
DWM Woes?
Requested by swarna in the Blur Busters Forums, is a scenario that investigates the effects of the DWM (Desktop Windows Manager, “Aero” in Windows 7) on G-SYNC in borderless and windowed mode.
Unlike exclusive fullscreen, which bypasses the DWM composition entirely, borderless and windowed mode rely on the DWM, which, due to its framebuffer, adds 1 frame of delay. The DWM can’t be disabled in Windows 10, and uses it’s own form of triple buffer V-SYNC (very similar to Fast Sync) that overrides all standard syncing solutions when borderless or windowed mode are in use.
To make sure this was the case, all combinations of NVCP and in-game V-SYNC, as well as the Windows 10 “Game Mode” and “fullscreen optimization” settings were tested to see if DWM could be disabled, and tearing could be introduced; it could not be, so Game Mode and fullscreen optimizations were disabled once again, and NVCP V-SYNC was re-enabled across scenarios for consistency’s sake.
The question is, does DWM add 1 frame of delay with G-SYNC using borderless and windowed mode?
Blur Buster's G-SYNC 101: Input Latency & Optimal Settings
Overwatch, shows that, no, with G-SYNC enabled, both borderless and windowed mode do not add 1 frame of delay over exclusive fullscreen. Standalone “V-SYNC,” however, does show the expected 1 frame of delay.
CS:GO was also tested for corroboration, and ought to have the same results, as DWM behavior is at the OS-level and should remain unchanged, regardless of the game…
Sure enough, again, G-SYNC sees no added delay, and V-SYNC sees the expected 1 frame of delay.
Further testing may be required, but it appears on the latest public build of Windows 10 with out-of-the-box settings (with or without “Game Mode”), G-SYNC somehow bypasses the 1 frame of delay added by the DWM. That said, I still don’t suggest borderless or windowed mode over exclusive fullscreen due to the 3-5% decrease in performance, but if these findings are true across configurations, it great news for games that only offer a borderless windowed option, or for multitaskers with secondary monitors.
3776 Comments For “G-SYNC 101”
olam
Member
olam
Hi, I would have two scenarios on which I’m not sure if I set it correctly in my case.
G-Sync + V-Sync are on
Game 1 – CS2 (FPS 99% exceeds refresh rate, Reflex available)
– FPS Limit 357 (I got 360 Hz)
– Reflex off (LLM also off)
Game 2 – PUBG (FPS rarely exceeding refresh rate, Reflex not available)
– FPS Limit 357
– Low Latency Mode -> On
Am I doing it right in this case?
If not, please correct me! Thanks in advance for your reply.
I just want to have the smoothest experience.
sc719
Member
sc719
I play competitive COD, on a 280Hz OLED, with average frames 300, 1% lows 220 and 5% 250…
To summarize theres basically 3 options you are suggesting?
1. Lowest tear free: VRR + Vsync + Reflex/AntiLag (or turn this off and have in game limit)
2. Absolute lowest response time: Uncapped + Reflex/AntiLag
3. Last: Capped
So the 1st option at worst it adds 1-2ms of delay from your results?
When I run the 1st option with Anti Lag, it goes to exactly 280 with 90% usage when idle but will go below throughout the game, is that an issue? I think in the comments you suggested either use reflex or manually set limit, but if i use reflex it is not -3 below monitor like the manual limit, however will dip below 280 throughout the game
Just wondering if i have this right here, thanks
fishman099
Member
fishman099
Hey all, just wanted to post to say thanks for the guide. Implemented as described a long time ago (took several reads lol) but still works superbly well today.
Wanted to also post for those newly discovering this guide.
My set up:
LG Oled B3
Windows 11 (but worked on 10)
RTX4070ti super
Ryzen 5700x3d
32gb ram
2xNvMe
I have my control panel set to:
Gsync enabled for both full screen and borderless
Desktop/game res: 1440p/120hz
LLM: on
Max frame rate: 114fps
Gsync: on
Vsync: on
In game:
Vsync: off
From the getgo, I know gsync engages as the LG (when in game mode) shows the gsync symbol.
So I’m a nerd, been gaming for years but was a total noob when it came to VRR/Gsync. I either never had the kit that allowed me to even experiment or I read basic guides online that lacked context or understanding of how it worked.
However as I’ve upgraded my rig THIS guide has been a godsend.
I think it’s worth saying that this ‘process’ is NOT a magic bullet as jorimt and the mods state several times. It doesn’t make frames or increases FPS BUT what it does do, for me, is allow my games to run at a FPS below my refresh rate that minimises stutter and maximises smoothness.
Also worth bearing in mind is the point that is made repeatedly, that you may, at some points, have to compromise on either resolution OR eye candy. My 4070ti super is potent but I run EVERYTHING at 1440p. Some would say compromise, but I disagree. A relatively consistent 1440p@120hz with plenty of eye candy is much more preferable than a constant 4k@60hz but lowered settings for me (YMMV).
Similarly, in my experience, to gain the most advantage from VRR/gsync frame rates need to be as much past 60 as possible – hence the 1440p/120hz decision.
My test games were always Sensuas Saga (Hellblade2) and Alan Wake 2 primarily because they played v.nicely with Gsync and are v.graphically challenging.
I use both DLSS and/or Frame Gen if required when gaming and tbh it is a flawless experience when coupled with VRR/Gsync. Id hit 90- 114fps on AW2 but because of Gsync it would always run lovely and smooth. Also I’m quite sensitive to input latency but having followed this guide I can honestly say I’ve not noticed any significant increase!
Anyway apologies for the wall of text, thought it might help peeps who are new to this to see that even a Gsync novice can make this work as intended. Just temper those expectations and follow the guide 👍
Ps thanks to jorimt for effort in putting this guide together – awesome!!
rubbahbandman
Member
rubbahbandman
One other thing, LLM should be disabled.
rubbahbandman
Member
rubbahbandman
I may have misunderstood your comment, but I think your settings are not quite optimal based on the g-sync guide.
First, it is a minor difference, but there really isn’t a need to cap your max framerate to 114fps on a 120hz panel. You might as well increase it to 117fps.
Secondly, this is a bigger issue, but g-sync should not be enabled for borderless/windowed mode. This can hurt performance by 3-5%+ which isn’t the end of the world, but why take the performance hit for such a minor benefit. Maybe if you are a streamer frequently going between windows, but the guide recommends this setting remain unchecked.
fishman099
Member
fishman099
@rubbahbandman – thanks for taking the time to respond 🙂
Fair points made but for clarity:
1. I engage LLM as some games don’t have reflex. My understanding of the guide jorimt has created is, if a game does have reflex and I enable it then it disengages the LLM setting in NVCP anyway? Also It’s worth noting that, as a rule, I don’t engage reflex when I set up my settings in game. In my experience there have been occasions where it causes more issues 8n game than it solves. However if I engage frame gen then the game will ordinarily auto engage reflex anyway.
2. Setting my refresh -6fps from my 120hz, for me, ensures that I never go above my refresh rate thus disengaging gsync. When I first set up using this guide I was set at 117/120 but occasionally my frames would bounce up to and sometimes over the 120? As per the guide I felt it better to guarantee that gsync stayed engaged by definitively setting it low enough to never breach my 120hz.
3. Borderless/windowed mode. I rarely play older stuff – sometimes games from the recent past. Where I am able, in those games, I select fullscreen this ensuring gsync is engaged. Conversely in most modern games I’ll select either fullscreen or borderless/windowed. As Jorimt states, the modern riff on this display selection in games means that gsync remains active, with little, if any, performance hit. (The better implementation of window/borderless was also a reason I moved over from W10 to W11).
Anyway, thanks for the input. It’s good to explore our settings and discuss them as, for me, it allows for better clarity on the subject!!
For better or worse I’m lazy so whilst I acknowledge that there are settings that should be engaged/disengaged per game I find it easier to set in NVCP and forget lol. I’ve yet to see a case in 18+ months where I’ve had to tweak anything but YMMV 🙂
rubbahbandman
Member
rubbahbandman
@fishman099
Thanks for the clarification. I see where you’re coming from now and think you have a better understanding of the guide than myself. I leaned a bit too hard on some outdated information.
Out of curiosity, how did you notice your frames bouncing over 120 and which GPU model are you using? I have a 5090 and may take a more similar approach similar to yours in case my gsync is also disengaging at times (even with a 117 fps cap).
As for the borderless/windowed mode, I did not realize this was more of a legacy issue, and similarly, LLM seems to function well now (under GPU limited conditions), so this is good for me to know.
Thanks again for your response!
fishman099
Member
fishman099
@rubbahbandman – Jorimt has answered your queries – better than I could 🤣🤣
But as layman I sorta played around with the frame rate limiter. I can’t remember if it was Jorimts guide or something I read elsewhere but my logic was that the difference (for me) between 117 and 114 was unmeasurable in real time terms – so thought I might as well ensure that the FPS doesn’t bounce?
In relation to Jorimts comment – I do actually use afterburner and understand that it’s entirely possible I was getting fakes positives but I also found it was potentially happening on a game by game basis!! Locking it to 114 just allowed me to not worry 😀😀
Btw – love the 5090 bro – what a monster of a gpu that is!!!
ToKc1n
Member
ToKc1n
Good evening, I’ve been writing comments for ages, but I’m still struggling to figure it out. Perhaps it’s just my personal preference. I have a 180Hz monitor, 5070 RTX, and 13600K. How can I properly configure the G Sync+ Vidia panel with a frame rate cap?
The problem is that games don’t support 180Hz. Take RDR 2 or Black Ops 6, for example, and they jump from 123 to 156.
I’m not entirely sure how to track trends or if it makes sense. When I turn on low latency to ultra or on, I get micro-freezing and a sluggish feeling. If I just enable G Sync in the panel and nothing else, then in GTA 5, I get 0.1-0.2 ms latency and FPS spikes from 300 to 500, but if I set the FPS cap to 177 or 172, I get micro-stuttering.
fishman099
Member
fishman099
I’m curious what res/graphics settings your running at?
Haven’t played either game for awhile but if the frame rate is jumping between 123 to 156 and your monitors refresh is 180hz then I assume your know where near hitting that.
As a novice (someone who’s used this guide successfully) I’ve just posted my settings but I run:
LLM: on
Gsync: on
Vsync: on
In game:
Vsync: off
If I’m able I also set NO in game frame limiter. In other words as my max refresh is 120hz I either select that is available or unlimited and let Gsync/NVCP do the rest.
The control panel settings, as far as I am concerned, are set and forget. When I do a fresh windows install I set the NVCP to those above and then every game I play turn off vsync immediately and either pick my monitors native refresh or unlimited.
Any game you play will allow you to select your native monitor refresh rate (if full screen). However I usually run window borderless which I understand to default to your desktop resolution/refresh anyway.
Have a play with my settings, see if they work as they are 1:1 with this guide. As I said in my post, this guide is amazing and does work. The hard part, for me, was trying to understand what each ‘setting’ did. Remember you can’t break anything and at worst have to reset your NVCP settings default 👍
ToKc1n
Member
ToKc1n
Thanks for your reply and responses.
Unfortunately, this setup only makes things worse. It might be because of Adaptive Sync in the monitor; I had it fully enabled, but the G-Sync setting disappears.
For example, if I do something simple, I have standard sync enabled on the monitor, vertical sync in the panel, and games disabled. Using the Riva tuner, I estimate 120 fps, which holds up, but I thought games would be heavy and lag. If I don’t limit the frame rates and leave the monitor at 180 fps, the frame rates seem lower, but they go past the threshold and rise to 181-182 Hz. I think G-Sync doesn’t work at all in that case.
If I turn low-latency mode on or ultra in the control panel, nothing changes except for a frame rate drop of 3-4 Hz. And in the game itself, if I have Nvidia Reflex, I also didn’t notice a difference between on or ultra + boost.
petran79
Member
petran79
I have an Asus Rog p348q monitor at 100 hz. Set frame rate cap at 97. I notice an issue with the updated Vulkan renderer in some applications. In Snes9x emulator for example, the games run at 48 fps instead of 60. I have to set Vulkan/OpenGL present method to Native.
While on Retroarch, on top of that step, I also have to enable “Application controlled refresh rate” option, same for Dolphin emulator where I have to disable max frame rate.
Recently I noticed a 2d game where I had to set nvidia panel frame rate to 120 in order for game to run at 60 fps instead of 48.
wpDiscuz
