G-SYNC 101: Range
Blur Buster's G-SYNC 101: Range Chart
Exceeds G-SYNC Range
G-SYNC + V-SYNC “Off”:
G-SYNC disengages, tearing begins display wide, no frame delay is added.
G-SYNC + V-SYNC “On”:
G-SYNC reverts to V-SYNC behavior when it can no longer adjust the refresh rate to the framerate, 2-6 frames (typically 2 frames; approximately an additional 33.2ms @60 Hz, 20ms @100 Hz, 13.8ms @144 Hz, etc) of delay is added as rendered frames begin to over-queue in both buffers, ultimately delaying their appearance on-screen.
G-SYNC + Fast Sync*:
G-SYNC disengages, Fast Sync engages, 0-1 frame of delay is added**.
*Fast Sync is best used with framerates in excess of 2x to 3x that of the display’s maximum refresh rate, as its third buffer selects from the “best” frame to display as the final render; the higher the sample rate, the better it functions. Do note, even at its most optimal, Fast Sync introduces uneven frame pacing, which can manifest as recurring microstutter.
**Refresh rate/framerate ratio dependent (see G-SYNC 101: G-SYNC vs. Fast Sync).
Within G-SYNC Range
Refer to “Upper & Lower Frametime Variances” section below…
The tearing inside the G-SYNC range with V-SYNC “Off” is caused by sudden frametime variances output by the system, which will vary in severity and frequency depending on both the efficiency of the given game engine, and the system’s ability (or inability) to deliver consistent frametimes.
G-SYNC + V-SYNC “Off” disables the G-SYNC module’s ability to compensate for sudden frametime variances, meaning, instead of aligning the next frame scan to the next scanout (the process that physically draws each frame, pixel by pixel, left to right, top to bottom on-screen), G-SYNC + V-SYNC “Off” will opt to start the next frame scan in the current scanout instead. This results in simultaneous delivery of more than one frame in a single scanout (tearing).
In the Upper FPS range, tearing will be limited to the bottom of the display. In the Lower FPS range (<36) where frametime spikes can occur (see What are Frametime Spikes?), full tearing will begin.
Without frametime compensation, G-SYNC functionality with V-SYNC “Off” is effectively “Adaptive G-SYNC,” and should be avoided for a tear-free experience (see G-SYNC 101: Optimal Settings & Conclusion).
This is how G-SYNC was originally intended to function. Unlike G-SYNC + V-SYNC “Off,” G-SYNC + V-SYNC “On” allows the G-SYNC module to compensate for sudden frametime variances by adhering to the scanout, which ensures the affected frame scan will complete in the current scanout before the next frame scan and scanout begin. This eliminates tearing within the G-SYNC range, in spite of the frametime variances encountered.
Frametime compensation with V-SYNC “On” is performed during the vertical blanking interval (the span between the previous and next frame scan), and, as such, does not delay single frame delivery within the G-SYNC range and is recommended for a tear-free experience (see G-SYNC 101: Optimal Settings & Conclusion).
G-SYNC + Fast Sync:
Upper FPS range: Fast Sync may engage, 1/2 to 1 frame of delay is added.
Lower FPS range: see “V-SYNC ‘On'” above.
Frametime spikes are an abrupt interruption of frames output by the system, and on a capable setup running an efficient game engine, typically occur due to loading screens, shader compilation, background asset streaming, auto saves, network activity, and/or the triggering of a script or physics system, but can also be exacerbated by an incapable setup, inefficient game engine, poor netcode, low RAM/VRAM and page file over usage, misconfigured (or limited game support for) SLI setups, faulty drivers, specific or excess background processes, in-game overlay or input device conflicts, or a combination of them all.
Not to be confused with other performance issues, like framerate slowdown or V-SYNC-induced stutter, frametime spikes manifest as the occasional hitch or pause, and usually last for mere micro to milliseconds at a time (seconds, in the worst of cases), plummeting the framerate to as low as the single digits, and concurrently raising the frametime to upwards of 1000ms before re-normalizing.
G-SYNC eliminates traditional V-SYNC stutter caused below the maximum refresh rate by repeated frames from delayed frame delivery, but frametime spikes still affect G-SYNC, since it can only mirror what the system is outputting. As such, when G-SYNC has nothing new to sync to for a frame or frames at a time, it must repeat the previous frame(s) until the system resumes new frame(s) output, which results in the visible interruption observed as stutter.
The more efficient the game engine, and the more capable the system running it, the less frametime spikes there are (and the shorter they last), but no setup can fully avoid their occurrence.
Minimum Refresh Range
Once the framerate reaches the approximate 36 and below mark, the G-SYNC module begins inserting duplicate refreshes per frame to maintain the panel’s minimum physical refresh rate, keep the display active, and smooth motion perception. If the framerate is at 36, the refresh rate will double to 72 Hz, at 18 frames, it will triple to 54 Hz, and so on. This behavior will continue down to 1 frame per second.
Regardless of the reported framerate and variable refresh rate of the display, the scanout speed will always be a match to the display’s current maximum refresh rate; 16.6ms @60Hz, 10ms @100 Hz, 6.9ms @144 Hz, and so on. G-SYNC’s ability to detach framerate and refresh rate from the scanout speed can have benefits such as faster frame delivery and reduced input lag on high refresh rate displays at lower fixed framerates (see G-SYNC 101: Hidden Benefits of High Refresh Rate G-SYNC).
3898 Comments For “G-SYNC 101”
mahmcud
Member
mahmcud
Hey, I followed the settings in this guide (G-SYNC and NVIDIA V-Sync enabled, with the NVIDIA Max Frame Rate limit set to 3 FPS below my monitor’s refresh rate), but I’m having an issue: in some games, such as RDR2, GTA V, and AC Shadows, using NVIDIA Control Panel’s Max Frame Rate limiter doesn’t feel smooth while other limiters like rtss work normal. Is there any way to fix this?
Robi
Member
Robi
Hey Jorimt, i did some testing again and found that in Cyberpunk2077 Frame Gen increases your latency in less gpu demanding areas, what do you know about this?
Here is my testings:
Question: Does DLSS Frame Generation increase PC Latency when GPU utilization decreases? (Cyberpunk 2077)
My settings:
– DLSS Super Resolution: Quality Transformer Model 2
– DLSS Frame Generation: 2×
– FPS cap: 157 RTSS (Async)
– NVIDIA Reflex: enabled (By default when FG)
– G-SYNC and V-Sync (NCP) configured correctly
– All graphics max + Path Tracing
My observations:
– In demanding areas, NVIDIA overlay PC Latency is around 35 ms.
– In less demanding areas, PC Latency rises to around 55 ms, despite lower GPU utilization.
– With Frame Generation disabled, I get around 100 FPS and 26 ms average latency.
– Interestingly, switching to DLAA while keeping Frame Generation enabled increases GPU utilization and reduces latency again but only in the less gpu demanding area.
I’ve repeated these tests, and I can feel the difference in responsiveness, I play lots of FPS games and I can physically feel the difference between 35ms and 55ms this is not a margin of error from Nvidia Overlay LAT.
Has anyone observed Frame Generation causing higher latency at lower GPU utilization?
wbotter
Member
wbotter
Hey! Wondering if V-Sync is applicable to Gsync Pulsar monitors? I just got one, went from PG27AQDM to the XG27AQNGV after receiving not one but TWO defective PG27AQWP-W’s!!! After the second AQWP-W started intermittently dropping signal due to the UHBR-20 handshake failing, works flawlessly in UHBR-13.5 with DSC, but for a $1250 monitor, I’d expect it to work as intended. So, I ultimately gave up on the flagship and was just searching for 27″ or less 1440p monitors over the 240hz my AQDM was already giving me, and the Gsync pulsar caught my eye. I had a BenQ Zowie with DyAc+ a few years ago and loved it, so yeah the curiosity got me with this monitor. I currently have a 9800x3d, cl 28 32gb 6000mhz, and a 5070. (Yes, Ik my gpu is hardcore limiting my FPS). I play competitive games mostly, in “comp settings” (basically low everything), DLSS Quality or Balanced using Model K, and I’ll get 384fps peaks, 271 avg, 202 1% lows and an average PCL of 10. All captured using frameview in marvel rivals after many many many “change one setting,” *capture for 45min-1hr of gameplay,* did this increase or decrease performance? lol! (All without DLSS FG. I’m not opposed to DLSS FG 2x, but 3x and above my PCL climbs quite a bit.)
Anyways, got any advice to get the most out of the GSYNC Pulsar Monitors? Or same rules apply? Thanks!!
user2422
Member
user2422
In an earlier comment you mentioned that ULLM is somewhat inefficient compared to Reflex or a manual limit, if i were to use Gsync + Vsync + ULLM, would that starving of the max queued frames and the potential stutters that come with it even apply considering that ULLM is auto limiting the fps in this configuration? Like does it limit low enough to prevent this from even happening?
Also when using Gsync + Vsync and then only enabling ULLM via Inspector without setting max pre-rendered frames to 1 (which ULLM would’ve otherwise done if it was applied via NVCP or NVApp), would this then be just an auto limiter without the other effects of ULLM? I’ve tried this configuration in-game and the auto limit still applies but I’m unsure whether or not ULLM will have any other impact in this configuration.
eonjr
Member
eonjr
Hi, thank you for the guides! But I have something to ask. My laptop has a 300hz refresh rate that is also GSync compatible. I have it capped at 285 using a formula that I saw on a Reddit post a while ago (via NVIDIA APP > Max Frame Rate).
I unfortunately get this gray flickering during gaming but I can get used to it. However, what I cannot stand is, when I tried using editing software (like Adobe Premiere Pro), the flickering was also present despite me having turned off GSync specifically for that app (via NVIDIA App). Is there something I am doing wrong? What can be done to completely eliminate flickering for non-game apps?
wpDiscuz
