This is the old page – please see new page:
CLICK: New Official 2017 List of Monitors
Below is the old 2014 list:
This is the old Blur Busters List of 120Hz, 144Hz and 240Hz computer monitors, including LightBoost monitors, gaming monitors, and overclockable monitors, including 1080p and 1440p monitors.
Type of Monitors: LightBoost | Overclockable | Samsung | Other
120Hz Monitors – Motion Blur Eliminating
Includes: LightBoost, ULMB (G-SYNC), EIZO Turbo 240, BENQ Blur Reduction
These monitors eliminate motion blur using an optional strobe backlight mode such as LightBoost. For more info, see TFTCentral: Motion Blur Reduction Backlights for explanations. Low-persistence strobe backlights allows LCD to have CRT motion clarity.
| Monitor | Size | Resolution | Refresh Rate | Technology |
| ASUS VG248QE | 24″ | 1920×1080 TN | 144Hz | LightBoost |
| ASUS VG248QE G-SYNC | 24″ | 1920×1080 TN | 144Hz | GSYNC / ULMB / PWM-Free |
| ASUS ROG PG278Q | 27″ | 2560×1440 TN | 144Hz | GSYNC / ULMB / PWM-Free |
| ASUS VG278HE | 27″ | 1920×1080 TN | 144Hz | LightBoost |
| ASUS VG278HR | 27″ | 1920×1080 TN | 144Hz | LightBoost |
| BENQ XL2420G | 24″ | 1920×1080 TN | 144Hz | GSYNC / ULMB / PWM-Free |
| BENQ XL2411T (Euro) | 24″ | 1920×1080 TN | 144Hz | LightBoost |
| BENQ XL2420TE (US/CAN) | 24″ | 1920×1080 TN | 144Hz | LightBoost / PWM-Free |
| BENQ XL2420T (Euro) | 24″ | 1920×1080 TN | 144Hz | LightBoost / PWM-Free |
| BENQ XL2720T | 27″ | 1920×1080 TN | 120Hz | LightBoost |
| BENQ XL2411Z* | 24″ | 1920×1080 TN | 144Hz | BENQ Blur Reduction / PWM-free |
| BENQ XL2420Z* | 24″ | 1920×1080 TN | 144Hz | BENQ Blur Reduction / PWM-free |
| BENQ XL2720Z* | 27″ | 1920×1080 TN | 144Hz | BENQ Blur Reduction / PWM-free |
| BENQ XL2430T | 24″ | 1920×1080 TN | 144Hz | BENQ Blur Reduction V2 / PWM-Free |
| ACER GN246HL | 24″ | 1920×1080 TN | 144Hz | LightBoost / ToastyX NOT supported |
| AOC G2460PG (Euro) | 24″ | 1920×1080 TN | 144Hz | GSYNC / ULMB / PWM-Free |
| Philips 272G5DYEB | 27″ | 1920×1080 TN | 144Hz | GSYNC / ULMB / PWM-Free |
| EIZO Foris FG2421 | 23.5″ | 1920×1080 VA | 120Hz native | Turbo 240 / PWM-Free |
*For BENQ Z-Series, these links include V2 firmware required for Strobe Utility.
Overclockable Monitors
These monitors are overclockable to 120Hz (or close), using either IPS or PLS panel technology, mainly Korean monitors. See the 120Hz 1440p IPS/PLS Guide.
| QNIX QX2710 Evolution 2 | 27″ | 2560×1440 | ~90Hz – 130Hz |
| X-Star DP2710 | 27″ | 2560×1440 | ~90Hz – 130Hz |
| Overlord Tempest X270OC | 27″ | 2560×1440 | ~90Hz – 130Hz |
| Overlord PCB Upgrade | 27″ | 2560×1440 | ~90Hz – 130Hz |
| Catleap 2B | 27″ | 2560×1440 | ~120Hz |
120Hz Monitors – Older LightBoost
These are older LightBoost monitors that are now discontinued.
| ASUS VG278H | 27″ | 1920×1080 TN | 120Hz | LightBoost |
| BENQ XL2420T (Rev 1.0) | 24″ | 1920×1080 TN | 120Hz | LightBoost |
| BENQ XL2420TX | 24″ | 1920×1080 TN | 120Hz | LightBoost |
| ACER HN274HB bmiiid | 27″ | 1920×1080 TN | 120Hz | LightBoost |
120Hz Monitors – Older Samsung (Strobed)
These Samsung monitors works with the Samsung Zero Motion Blur HOWTO.
However, most of these Samsung monitors are discontinued.
| Samsung S23A700D | 23″ | 1920×1080 | 120Hz |
| Samsung S23A750D | 23″ | 1920×1080 | 120Hz |
| Samsung S23A950D | 23″ | 1920×1080 | 120Hz |
| Samsung S27A700D | 27″ | 1920×1080 | 120Hz |
| Samsung S27A750D | 27″ | 1920×1080 | 120Hz |
| Samsung S27A950D | 27″ | 1920×1080 | 120Hz |
120Hz Monitors – Other
These monitors do not have a motion blur reduction strobe backlight.
Most are older 120Hz displays that are discontinued, while some displays are newer.
| Philips 242G5DJEB | 24″ | 1920×1080 | 144Hz |
| AOC g2460Pqu | 24″ | 1920×1080 | 144Hz |
| ASUS VG236H | 23″ | 1920×1080 | 120Hz |
| ASUS VG236HE | 23″ | 1920×1080 | 120Hz |
| BENQ XL2410T | 24″ | 1920×1080 | 120Hz |
| ACER GD245HQ, GN245HQ | 24″ | 1920×1080 | 120Hz |
| ACER GD235HZ | 23″ | 1920×1080 | 120Hz |
| ACER HN274H bmiiid | 27″ | 1920×1080 | 120Hz |
| Iiyama Prolite GB2488HSU-B1 | 27″ | 1920×1080 | 144Hz |
| Iiyama Prolite G2773HS | 27″ | 1920×1080 | 120Hz |
| Alienware AW2310 | 23″ | 1920×1080 | 120Hz |
| Planar SA2311W | 23″ | 1920×1080 | 120Hz |
| LG W2363D-PF | 23″ | 1920×1080 | 120Hz |
| Hanns-G HS233H3B | 23″ | 1920×1080 | 120Hz |
| Samsung 2233rz | 22″ | 1680×1050 | 120Hz |
| Viewsonic VX2265wm, VX2268wm | 22″ | 1680×1050 | 120Hz |
| Viewsonic V3D245 | 24″ | 1920×1080 | 120Hz |
True 120Hz Televisions / Projectors
Some HDTV and projectors can be used as a 120Hz computer monitor, see HDTV Overclocking HOWTO: 120Hz from PC to TV. There are others, however, the displays below are carefully selected displays with consistent success reports of true 120Hz.
| SEIKI 4K HDTV – 50″ Version (not 39″) | 50″ | 1920×1080 | 120Hz (during 1920×1080) |
| Optoma GT720 DLP Projector | >100″ | 1280×720 | 120Hz |
| Optoma GT750 DLP Projector | >100″ | 1280×720 | 120Hz |
Specialty 120Hz Monitors
These monitors are targeted towards scientific purposes. These monitors will typically massively outperform all other 120Hz flat panel monitors. These are expensive 120Hz IPS and 120Hz VA panels, rather than TN panels.
| VIEWPixx Scientific Display | 22″ | 1920×1200 IPS | 120Hz |
| Eizo FDF2405W | 23.5″ | 1920×1080 VA | 120Hz native / 240Hz internal |
Additions & Questions?
For questions, come post in the new Blur Busters Forums! Heard of a new new 120Hz display? Tell us about it, such as a new LightBoost monitor, or a missing 120Hz monitor of any LCD / LED / flat panel type, that can accept a 120Hz refresh rate, 240Hz monitors, strobe backlight monitors, or similar. This list of 120Hz gaming monitors is current as of 2013.
