The use of Boot Camp and SwitchResX makes LightBoost possible under Mac OS X, running an AMD or NVIDIA GPU (non-Optimus, without an Intel GPU alongside NVIDIA GPU). From this, it is easy to enable LightBoost on a 120Hz monitor on a Mac by:
1. Use a DisplayPort cable (mini-DP to full DP)
2. Connect a supported 120Hz monitor
3. Reboot to Windows via Boot Camp
4. Initialize LightBoost via ToastyX Strobelight
5. Reboot to OS X
6. Install SwitchResX
7. Disable “Use simplified timings” checkbox
8. Set “Scan Rate” under “Vertical” to 120
9. Set “Total” under “Vertical” to 1147
(Increase Back Porch if necessary to do so)
10. Click OK
11. You are now LightBoosted on Mac!
