EIZO announces Foris FG2421, a 240Hz VA gaming monitor!
Eizo has announced the Foris FG2421, a new 240Hz VA monitor has been released! This is the retail gaming version of the previously released FDF2405W professional monitor which also uses a official/optional strobe backlight setting to eliminate motion blur. No interpolation is used!
Blur Busters is being sent a review unit from Eizo, and it will be arriving this month. And, yes, we will benchmark it against LightBoost. Being a VA panel with a LightBoost-like strobe backlight without color problems, we would naturally expect it to vastly outperform LightBoost quality, while also being easy to enable on any graphics card.
See the Eizo white paper about how the Turbo240 strobe backlight operates.  Also, this monitor can be 100% PWM free when you disable Turbo240, for the best of both worlds!
EDIT: FG2421 is now now available on Amazon.com.
About Mark Rejhon
Also known as Chief Blur Buster. Founder of Blur Busters. Inventor of TestUFO. Read more about him on the About Mark page.
31 Comments For “EIZO announces Foris FG2421, a 240Hz VA gaming monitor!”
Eric Wang
Member
Eric Wang
On page 12 of its manual states that it accepts 24hz signal over HDMI.
http://www.eizo.co.jp/support/db/files/manuals/03V24721A2/Manual-JA.pdf
Quite curious if Turbo240 can be enabled when using 24hz mode.
I love watching movies with film-style motion xD (24p shutter at 48 or 72hz).
boniek
Guest
boniek
No g-sync? Also would love to know if standard VA panel weaknesses are present (like brutal color shift).
CYBER-NINJA
Member
CYBER-NINJA
Cool Eizo Foris FG2421 promo vid on YT:-
http://www.youtube.com/watch?v=0vE3br4H2aI
A good in-depth review can be found here:-
http://www.flatpanelshd.com/review.php?subaction=showfull&id=1383107475
For Sellers and Distributors just select your country from the Global drop-down menu and then look in the bottom right corner:-
http://www.eizo.com/global/
They also sell direct in NA too!!! 😉
Ewok
Member
Ewok
Also, this monitor is 100% PWM free when you disable Turbo240, for the best of both worlds!
Are you sure? The white paper you linked in your comment mentions “high-rate PWM”.
wpDiscuz
Recent Content
