Iiyama announced the new GB3266QSU-B1 in the Red Eagle line. While the model name may be a bit of a mouthful to say, the specs speak for themselves.
The iiyama G-Master GB3266QSU-BI from the Red Eagle range is a 31.5-inch 144Hz refresh rate monitor with a 1500R curvature. The official site says that the VA panel has a 1ms MPRT response time and features a full-on 2560×1440 resolution. The monitor has AMD FreeSync Premium too.
It has height, tilt, and swivel adjustments, and also comes with two 5W speakers and a lot of connectivity. There are two HDMI ports, two Display 1.2 ports, two USB 3.0 ports, and two USB 2.0 ports, so if you need to connect some stuff to it, you can. Oh, and there’s also a headphone jack too.
Iiyama G-Master GB3266QSU-B1
- 31.5-inch Curved VA Display
- 2560×1440 at 144Hz
- 1ms MPRT Response Time
- AMD FreeSync Premium
