Acer’s Nitro VG272UV is looking likely to start being launched in Europe according to a report on DisplaySpecification.
The monitor in question has a 27-inch IPS display with a 2560×1440 resolution. The monitor also sports a 165Hz refresh rate, with the ability to be overclocked to 170Hz. Not only does it have a 2ms response time, 400 nits of typical brightness, and a 1000:1 static contrast ratio, but it also has support for AMD FreeSync and DisplayHDR 400 support.
Currently, Acer’s UK store has the monitor listed but not yet on sale, so only time will tell if and when the monitor makes its way across to the US. The VG272U has tilt, swivel and height adjustment support and has the standard Acer bells and whistles such as Flicker-free and low blue light.
Acer VG272U V
- 27-inch IPS Display
- 2560×1440 at 165Hz
- 2ms Response Time
- AMD FreeSync
